Jd A
Scott
10-25-2000 20:18:47
What is the correct gap for spark plugs for my tractor, and also, is a coil any different for a John deere than it is for a Farmall?
John Ne.
10-25-2000 22:10:15
 Re: Jd A in reply to Scott, 10-25-2000 20:18:47
Scott, you'll find the tune up specs, and plug gap to the left of the screen under tune up specs,,,a coil is universal, just hook the pos. and neg. wires to the correct posts. remember a pos. ground 6 volt system has the Hot lead to the Neg. post. all negative ground systems, put the Hot lead to the Pos. post. other wise the coil will not last too long, it'll run for awhile.
