B ammeter discharges
AS
10-25-2000 08:38:15
I got my B generator, voltage regulator and wiring finished. The ammeter goes on discharge when the tractor is running. The higher the rpm the more it discharges. Could I have my wire hooked to the wrong terminal on the ammeter. I am using a voltage regulator instead of a cut out relay. Any help appreciated.
Jack
10-27-2000 19:31:08
 Re: B ammeter discharges in reply to AS, 10-25-2000 08:38:15
Did you, perchance, put the battery in backwards?
John T
10-25-2000 14:49:42
I agree with my Ol buddy Bill there you may have it wired backwards. If its an original Positive Ground Tractor, the - on ammeter gets to the battery - to charge it, while the + goes to the generator and lights and coil etc. Try turning the ignition or lights on like he said, and if it shows charging, its wired backwards. Reverse the leads should fix her. John T
Bill {Antique Acres}
10-25-2000 11:57:10
I would bet you need to swap the wires on the back of the amp gauge. Turn your lights on with the tractor off and see if goes into the chrge side. If so they are on backwards. Bill {Antique Acres}
