John Deere D Info
S Salm
10-23-2000 15:01:12
I just purchased a 1930 Model D. Does anyone have a clue on how to clean the fuel tank? The tractor was restored but gas was left in the tank and went bad. Smells like varinish. Fuel lines seem plugged. I am sure the carb is in the same shape. Was there originally a gas bowl on this tractor? This one does not have one. Any other info about 1930 D's would be helpful. Thanks
S Salm
Ralph
10-23-2000 17:16:05
 Re: John Deere D Info in reply to S Salm, 10-23-2000 15:01:12
Welcome to the varnish club. I bought a "D" a few years ago that supposedly had been started every Labor Day for 25 years. You do have "varnish". I dug it out with a twist drill in the ends of the gas line. I used 2 - 3 gallons of acetone. Later I dumped in a couple of pounds of fish tank gravel and sat on a stool and rocked the tank back and forth on my knees for about an hour. I also stuck about 2' of 1/8 to 1/4" rubber tubing inside the inverted tank, hooked it up to the water line and let that slap around for a 15 minutes. I also filled the tank with water and stuck a live steam line in the tank. The acetone and gravel were effective, but I did not give the acetone enough time to work. The water and steam werer a waste of time. Sadly I still have varnish or rust flaking off the sides of the tank. I will either take the tank off, send it to PA(?) for sandblasting and coating, or will buy another gallon of acetone and dump it in a cup or quart at a time. Seal the tank, slosh it around periodically, dumping it out the next day and repeating until I have it clean. Dissolving layers of varnish does not occur rapidly. WARNING!!! Contrary to what a Welder told me, acetone is flammable, explosive and every bit as bad as gasoline. Do not shake gravel around in the tank with acetone nor do anything else that will ignite the acetone vapors, i.e. smoking. Also work outside preferably with a slight breeze.Acetone is soluble in water but the addition of small amounts of water detracts from its solvent characteristics.
