Correct carburator
Wayne
10-23-2000 09:45:29
I have a '35 B. I know the correct carburator is a DLTX 10 but where do I find the casting number? On the side with the load jet I can see DLTX so I know it is a DLTX carb. After the DLTX there is a small raised area on the carb and the number 53 is stamped in to this spot. But before the DLTX right near the jet it almost looks like there is a very, very worn 10 which would make this the correct carb. I'm a little suspect because the choke lever has a hole for the choke rod which I woulnd't expect on this early of a B. Thanks, Wayne
Mike Aylward
10-23-2000 11:06:45
 Re: Correct carburator in reply to Wayne, 10-23-2000 09:45:29
Wayne, the identification number is on the right side of the carburetor just in front of the load needle, and just behind the front mounting flange. I have a 10 carburetor if you need it, and might trade if your's is a 53 and rebuildable. The 53 carburetor is for a styled A before '47. Hope this helps. Mike
Wayne
10-24-2000 09:26:14
 Re: Re: Correct carburator in reply to Mike Aylward, 10-23-2000 11:06:45
Mike,
Thanks for getting back to me. Based on the DLTX 10 carb you have could you tell me exactly where I find the '10' in relation to the letters DLTX. Just in front of the load needle before the letters DLTX it looks like it may be a worn off 10 but right after the DLTX there is the raised area that is just big enough to hold the number 53. Thanks, Wayne
