Oil pump in JD-A
john
10-20-2000 14:06:13
I drove a JD-A the other day a few miles down the road and noticed that none of the gagues were working. The amp meter most likely didn't work due to bad looking generator and volt regulator. The temp gage was also not working possibly because of rust on the bi-metallic wire leading to it. The oil gage however looked clean and wasn't ruptured inside. Does anyone know of a check to do that would verify if the oil pump is infact working or not? (yes, the engine had oil) Thanks
clooney
10-20-2000 15:45:13
 Re: Oil pump in JD-A in reply to john, 10-20-2000 14:06:13
John, the best test is to install a known good gauge. If you are just worried about the oil pump working, remove the gauge line from the fitting on the crankcase & see if oil is being pumped out of the fitting. If you have a warped filter head inside the crankcase ( from overtightning the filter can nut) the oil pump could be pumping but the oil could be running out before it gets to the bearings or gauge so it would a good idea to verify that you really do have oil pressure.
