JD 50 60 Power-trol
BEN SO TEX
10-19-2000 17:40:33
Can the back of the plug be drilled out and threaded, and then can I put a short piece of hydraulic hose with a female end so I can use my cylinders from the other tractor? Can the plug take that pressuer? Reason I asked these question is because, I do not have the males that go into the back of the prower trol. Thanks
PaulCtOH
10-21-2000 10:25:39
 Re: JD 50 60 Power-trol in reply to BEN SO TEX, 10-19-2000 17:40:33
Aren't there a couple of plugs on the right side of that pow'r trol that you can unscrew and put pipe elbows into? I had a 70 fixed up that way.
ToddT
10-20-2000 09:42:38
Take a look at this service bulletin about setting up your Powr-Trol for remote cylinder operation ever without the remote plugs.
Also, even without the selector valve mentioned, there are ways to keep the rockshaft from working when the cylinder is in use. Take a look at the bottom of this page.
Hope this helps!
Deerejon 2000
10-20-2000 03:55:34
If you're talking about the plugs that are used to activate the rocker shaft, they are different than the remote cylinder plugs internally. The remote cylinder plugs have side ports, the rocker shaft plugs don't. That's why you can't make the rocker shaft operate by capping the remote cylinder plugs. This is nessecary so that both the rocker shaft and cylinder don't operate at the same time, the one without a load first.
