4010 Diesel Trouble starting
Mitch Sweeney
10-19-2000 15:32:42
We have a 4010 that we can't start. The solenoid clicks but the engine does not turn over. We have replaced the batteries and the starter with a remanufactured starter. It will run if pulled. Does anyone have a wiring diagram for the starter? Any other suggestions?
Thanks,
Mitch Sweeney
Mitch Sweeney
10-19-2000 15:52:30
 Re: 4010 Diesel Trouble starting in reply to Mitch Sweeney, 10-19-2000 15:32:42
Never fails. As soon as you ask for help you figure out the problem. It seems that a wire from the battery was too short and when we tightened it it pinched another wire against the frame causing it to short out.
Thanks for your help,
Mitch Sweeney
