430 hydraulics
Dale Kite
10-18-2000 16:57:53
I have a 430w when you raise the hydraulic lever 3/4 of the way up it will eventually go the rest of the way by itself then the lift will jump and jerk, any help will be appreciated.
clooney
10-18-2000 18:08:38
 Re: 430 hydraulics in reply to Dale Kite, 10-18-2000 16:57:53
Dale, are you talking about the control lever moving & jumping or the draft links?
Dale Kite
10-19-2000 16:47:25
 Re: Re: 430 hydraulics in reply to clooney, 10-18-2000 18:08:38
The control lever moves by itself at about 3/4 of the way up and so do the lift arms.
clooney
10-20-2000 15:52:32
 Re: Re: Re: 430 hydraulics in reply to Dale Kite, 10-19-2000 16:47:25
Dale, if the problem goes away when you hold the control lever in one place then it is probably the friction disks on the quadrant lever. If it still acts as you describe then it could be a loose control rod, bent linkage, sticking valve or worn pivot pins inside the touch-o-matic.
