Distributors on model B late styled
mark burchard
10-18-2000 15:59:03
Does anyone out there know if the distributor on the late styled model "B" , ser# 210***, is original, or has it replaced an original wico magneto? The best info I can find says the distributor became standard after ser# 268820, but was it an option prior to that on 1948 late styled "B"s. Thanks, Mark
Craig
10-19-2000 16:59:07
 Re: distributors on model B late styled in reply to mark burchard, 10-18-2000 15:59:03
Do you have the Wico distributor that looks almost exactly like a magneto or the Delco Remy distributor as used on the 50 & 60 tractors?
I would say someone has replace the Wico mag with the distributor. A distributor was never offered (to the best of my knowledge) prior to the serial number you mentioned. I changed my 1950 B (sn 263xxx) from mag to distributor and it runs much nicer especially at lower RPM's. I think it has much hotter spark at low RPM's than the mag.
