3 point hitch 420s
mike mclemore
11-12-2003 07:34:33
on my 1957 john deere 420s on the 3 point hitch i am told that wood blocks are suppose to be installed to keep the third arms from getting into the tires. can anyone explain this to me, and let me know the size of them or if sold aftermaket. thanks
Henry J
11-12-2003 10:01:18
 Re: 3 point hitch 420s in reply to mike mclemore, 11-12-2003 07:34:33
Mike
As Wayne said. They have basically the same set up as the ford 9N, 2N, 8N family, except that the chain attaches to the tractor different.
Wayne in Tn.
11-12-2003 07:59:56
Mike, you have been misinformed about the wood blocks. Your tractor should have (sway) chains, that hook at the center of the lift arms and then to the drawbar with a bolt dropped through. The sway can be adjusted by taking up links in the chains or by different pin holes in the drawbar. Some of the bigger or later tractors did have sway blocks that were made of steel.
