4430 Quad Range
Michael Ridenho
10-13-2003 21:05:08
I recently bought a 4430 with Quad Range. The two speed does not work. You can move the lever side to side but it does nothing. The linkages had some slop in it and I corrected that to no avail.
I have gears 2 and 4 I think, which work fine but it would be nice to have 1 and 3. Does anyone have any idea what could be wrong and how to correct it?
Thanks
Michael Ridenhour
david val
10-14-2003 05:20:19
 Re: 4430 Quad Range in reply to Michael Ridenhour, 10-13-2003 21:05:08
disconnect the link coming down from the shift quadrant to the bellcrank at the bellcrank. try to shift hi-lo by the bellcrank. you shoud feel two detent positions. if you don't, the fork for the hi-lo inside is probably broken (tractor split is nessessary for repair). if you feel the detent check if link corespondes with its' hole in the bellcrank in low (1 or 3) and in high (2 and 4).
if it doesn't, you can adjust the other link connected to the bellcrank.
(if you have a pc, bellcrank is R52645. link is R52648, and adjustible link is R52644).
david
Jim B
10-14-2003 04:57:21
Micheal,there is a short line on 2 speed clutch pack that has a clamp on it that breaks and lets end of line come out of c/pack.Worst case would be oring or clutches bad in c/pack which would mean a split is in order.Get a tech manual and check hyd.pressure's.Did you check linkage all the way to tranny because I remember something under S/gard that flipped to control 2 speed but it's been 15 yr's since I worked for JD dealer.HTH,Jim B
