John Deere A Woes Update
Colt Edin
10-15-2000 17:53:47
Well, today was the big day. After sitting in the barn for about 2 weeks we decided to tear into it and see what on earth had made it make some ghastly noises (not metal to metal knocks) and smoke white really bad and then die. The engine was not locked up but squirted oil out back through the carburator and out some hose uptop on the engine. We started at about 2 o'clock and removed all of the stuff in the way to remove the head. At 4:30 the head came off and we gave it a look... There is a crack all the way between the valves on the left side. Definately not good. It goes all of the way through the seat for the valve and looks unweldable. Darn! Also, face of the block where the head gasket sets has a worn and slightly pitted (maybe a few thousandths of an inch) spot between the cylinders that is slightly blackened. Not good, either!
Anyways, does anybody out there know how much blocks cost? This tractor can be seen in the John Deere photo gallery as the 1947 JD. A. by Colt Edin.
Thanks,
CE
Karl Bader
10-16-2000 04:56:31
 Re: John Deere A Woes Update in reply to Colt Edin, 10-15-2000 17:53:47
try these places:
www.salvagetractors.com
www.oldjd4u.com
Hope this helps!
Karl
rollo
10-15-2000 18:57:46
try these guys (www.2-cylinder.com) or greg stephen at 303 663-5246..Good luck
