Good Morning there John, First, when you say it "stays engaged" but disengages when you turn off the ignition switch, that sounds like the starter motor (via solenoid and push switch) is staying engaged "electrically" AS OPPOSED TO the starter drive being "mechanically" stuck into the flywheel teeth. If it (starter drive) was "mechanically" stuck into the flywheel teeth and engine kept running, release of the solenoid may not make any difference BUT if the starter is stayign engaged "electrically", a loss of power to the electrical starter solenoid would allow its release. Do you mean that once started you momentarily turn the ignition off then right back on (quickly so the engine keeps running) then the starter is free????? ????? If so, the push switch may be hanging in. HOWEVER, if the push switch was still stuck in/down AFTER you turn the ignition switch back on (quick so engine kept running), the solenoid would try to re engage the starter and it would grind its teeth with the flywheel. It depends on how long the push switch may be stuck down engaged till it releases fully????? IF YOU TURN OFF THEN QUICKLY BACK ON THE IGNITION, does the starter try to re engage and/or grind its teeth????? ?? OR Do you mean you just turn her off PERIOD in which case the solenoid isnt engaged and the starter motor or engines no longer running ????? If so, does she start right back up and sound like the starter drive engages the flywheel and she cranks over ORRRRR R Is it like the drive is permanently stuck into the flywheel and pushing the start switch starts her but she stays engaged until you turn the tractor completely off??? If thats the case, the drive may be stuck mechanically into the flywheel in which case you may need to rock the flywheel or loosen the starter and get it UNSTUCK before you harm the starter and drive. *********ELECTRICAL STICKING******************** IF turning off the switch releases the starter AND IF the start push switch derives its power from the ignition switch such that it being OFF kills power to (feed) the push start switch, the push switch may be hanging in. That could be a mechanical corrosion sticking problem causing the switch to be stuck in for a while until it vibrates free. DOES THE PUSH BUTTON POP BACK OUT FULLY IMMEDIATELY AFTER YOU RELEASE IT???? Exercise and WD 40 and air may clean up the switch if its getting mechanically stuck and hanging in. ***********TROUBLESHOOTING PUSH SWITCH***********
1) Remove the wire from the push switch going down to the starter solenoid (so pushing it dont engage the starter motor and solenoid) and place a test lamp on the terminal and have ignition switch on. Then push it and the lamp should come on BUTTTTT when released it should go immedialey OFF. DOES THAT HAPPEN??? If the lamp stays lit long after the push button is released, its hanging in stuck mechanically which air and wd 40 may cure or it may need replaced. It (switch terminal going down to starter solenoid) should light when pushed down but go off immediatley when released. Finally, you asked about starter drive repair if its a mechancical drive stickign problem and NOT the electrical problems described above. It may be possible to remove the starter and thoroughly clean and re lube the starter drive. I use light lithium grease on them, if she still mechanically sticks into teh flywheel, the starter mounting may be loose or the drive simply needs replaced. Sorry John, but from your description I couldnt tell if you were turning the ignition switch off PERIOD to stop the start motor form engaging or you meant you tuned it off then quickly back on she released and the engine kept running??? If she is hanging in electrically from a sticking switch, a repair or replacement may cure the problem. Do the start push switch test above to see. If the starter drive is stuck mechanically into the flywheel all the time and you have to turn the ignition off period to stop it, the drive needs attention and rock the flywheel and loosen the starter and see if you can clean and re lube the dive mechanism. Post back your results and test the push switch and e mail or post any more questions [email protected] and we can proceed further if needed. Good luck n God Bless ya John John T Nordhoff
