If you overhauled a 3020/3010 for 1500USD, then in my opinion you didn't do what I would consider a complete overhaul. I had my 3010 diesel overhauled a couple of years ago. The labor was free, so my only cost was parts, planing the block and taking a little off the pistons. I had to get a new camshaft, so that brought cost up more than I had anticipated. All parts were JD. I didn't have to do anything but put a 20USD kit into the injector pump, no work on the injectors. The work cost me a little over 3800USD. I could have bought parts from some after market places, but those kits still ran nearly 1000USD (I believe the one from deere only cost 200 - 400 more). The block work got expensive. Supposedly the place that worked on it said it was the worst block they had every worked on...claimed if it needed to be done again I'd have to throw the block away. I had anything with wear replaced. Many probably would not have replaced the camshaft if they were doing it themselves. I overhauled the engine because of the labor free opportunity and the fact that I wasn't sure how sound the engine was (although it had been running fine). My main worry was the black liquid that was leaking through the exhaust manifold which was likely due to the injectors...before I had them rebuilt the year before the overhaul. I hadn't notice the black stuff after redoing the injectors, but I was concerned about "what else" may not be up to par. Supposedly this tractor had been overhauled not to many hours before I had bought it, but they were not sure. Based on what we found when overhauling the engine, I'd say it wasn't or was one of the cheapest jobs ever. When it comes to fixing things, some would say I am probably a purest...When it is mine, I want it fixed right with all parts in like new condition. As tough as these engines are, doing a limited overhaul will probably get you through a lot of years. I wanted to make sure I'd not have to do it again in my life time. Maybe I wasted money. Anyway, now you have another description of why some say it costs so much to overhaul...take it for what its worth...
