Flywheel wobbel
Ken Hinman
10-13-2000 14:48:13
The flywheel on my 1944 Model A has a wobble in it. Yes it is tight on the crankshaft. There is .002 difference on the backside at the crankshaft. That is, I have it set at .006 on one side and the other side is .008. Is this anything I need to be concerned about?
Hand Clutch
10-13-2000 20:07:56
 Re: Flywheel wobbel in reply to Ken Hinman, 10-13-2000 14:48:13
when people say "IS IT TIGHT ON THE CRANK" they mean does the flywheel fit onto the crank tightly radially.ie..the bolts may be tight that hold the flywheel to the crank but if there is ANY slight egg shape to either component the flywheel may still be loose on the crank....hope this helps with the question, Handclutch
