JD H Plow
Don
10-12-2000 04:39:40
My H has a single bottom plow mounted via a long bar which attaches to the main rails under the engine (2 bolts) and a hanging position mounted to a spring loaded lever mounted on the rear axle (no PowrLift). I'm trying to identify the Model #. The moldboard has a metal tab attached with the letters "1451, KN, SCPO" and the Gauge Wheel Hub has the following cast into it: JD C515A (on one side) and JD G514A (on the other side). In addition there is a sheet metal tab under one of the hub bolts with the letters (I think) "No 8, GWH". Thanks in advance to anybody who can help identify the plow and suggest where to get literature on it.
Don
Bob
10-12-2000 17:07:18
 Re: JD H Plow in reply to Don, 10-12-2000 04:39:40
Don, This is most likely an H-1 plow made by John Deere for the H tractor. A parts book is available and, I think, an operators manual also is available from John Deere. These are your most valuable source of correct info. By the way, since plows were fitted with bottoms suitable for the land being plowed, often the dealer or purchaser made the decision and the numbers , in this case 1451, are not of any use in identifying the plow itself, but of course it IS a great help when trying to get parts for the bottom, points, landsides etc. Also the bottoms are NOT included in the parts books for the plows for that same reason. Hope this helps, Bob
