730 reverce to fast
Greg A
10-11-2000 18:04:37
can I get different gears to slow down reverce
Deerejon 2000
10-13-2000 17:25:34
 Re: 730 reverce to fast in reply to Greg A, 10-11-2000 18:04:37
If I remember the JD transmissions corretly, reverse is obtained by engaging the 1st gear primary gear directly to the differential drive gear without going through the secondary shaft. Since the distance between these two is fixed, there is no way to change the gear ratio. In a four speed '40 B we have, reverse is faster than 4th gear, which is why some farmers would use it as road gear by driving down the road backwards.
reverse maybe?
10-12-2000 10:07:16
do you mean reverse?
