36 A help PLEASE!!!
Dwight
10-09-2000 17:47:25
Have a 36 A puller that is turning 1300 rpms but as soon as I hook to the sled the tractor seems to be hardly turning at all.Tried everthing I know what do you suggest??? Any help appreciated.
Thanks in advance,
Dwight
zane
10-10-2000 07:16:47
 Re: 36 A help PLEASE!!! in reply to Dwight, 10-09-2000 17:47:25
You say your tractor is a "Puller". What have you changed from stock to make it a puller? 1300 rpm is 33% faster than the engine was designed to run. I'm sure the standard carb/air supply system will not support that rpm under load.
Wayne Swenson
10-09-2000 19:49:34
Have someone watch the throttle arm on the carb when you attempt to work the engine. The throttle valve should be open all the way to the stop when under max. load.
Is your governor working correctly??
Good luck! :)
Bill T
10-09-2000 18:23:37
Dwight, Try painting your '36 A red!
Todd
10-09-2000 20:37:57
 Re: Re: 36 A help PLEASE!!! in reply to Bill T, 10-09-2000 18:23:37
If he did that it probably wouln't run.
Hand Clutch
10-11-2000 19:34:06
 Re: Re: Re: 36 A help PLEASE!!! in reply to Todd, 10-09-2000 20:37:57
...and how much different is that than his current problem???
