JD500seriesA backhoe, Roosa-Master problem
Paul Hatch
10-08-2000 09:51:24
My ancient but solid workhorse, 1973 serial series 130,000 JD 500 series A backhoe has been excellent for the 20 years I have owned it. When I purchased it it already had 4200 hours on road construction. Two weeks ago after operating backhoe for 2 hours diging out drainage ditch I turned of engine to speek to someone. When I started engine it began running on only three of four cylinders and heavy white smoke. I checked fuel system, some dirt had gotten into fuel pump and had cut a hole in the settling bowl screen. I replaced screen, installed new filters, drained off bottem of fuel tank, still 3 cylenders and white smoke. I installed new injector in cold cylender, no change. Any ideas?
ROBERT
10-08-2000 10:49:53
 Re: JD500seriesA backhoe, Roosa-Master problem in reply to Paul Hatch, 10-08-2000 09:51:24
crack the line to the cold cyl and see how much
fuel come out whil it idals (may have to compare it too a good cly.)if the fule flow looks low
the lob in the inj pump may be wore down. if the flow looks good you may have a bad valve
in the head.you may have to borw a comprason tester and check all cyls. hope this help some ROBERT
