Is this original for a 1950 John Deere B?
Karl Bader
10-07-2000 06:18:28
My gear shifter has a screw on head or top to it... Is this original or no?
Thanks,
Karl
The Rest of the Storey...........
10-16-2000 20:40:10
 Re: Is this original for a 1950 John Deere B? in reply to Karl Bader, 10-07-2000 06:18:28
The B never came with a knob. The knob was added when they made the 50 tractors. The original B shift lever (one part number) was subbed over to the model 50 shift lever with the knob (two part numbers, one for lever, other for knob). If you go to your Deere dealer today (or back in 1953)and order the original B shift lever, you will receive the shift lever made for the model 50 knob. The knob has to be ordered by its own part number. My new PC-330 parts catalog shows the sub numbers (which is the same as for Model 50). I recently changed my B over to the lever with the knob because it sure makes it a lot easier to shift rather than that straight stub sticking up. (Plus, my old lever was bent inside the trans and did not help the matter either).
deerejon2000
10-09-2000 19:49:49
Some farmers replaced the shifter on "B"s with a "50" shifter, if it has a screw-on shifter knob, its from a "50".
Kris
10-09-2000 10:39:12
Once again Stan you are the man. I've got a 51 B no screw on top and never even heard of one on a Lettered JD!!
Clyde Scott
10-08-2000 04:58:06
Karl:
I have a 1950 "B" that also has a screw on knob for the shifter.. I have often wondered the same about originality.. Thanks for the question and maybe someone can give us the correct answer.
Clyde Scott - Mou;tirie, GA.
Stan
10-08-2000 16:17:45
 Re: Re: Is this original for a 1950 John Deere B? in reply to Clyde Scott, 10-08-2000 04:58:06
You might want to read the two prior posts on this subject. I also looked in my Parts Catalog (PC330) to see what is shown there - no knob on the top of the shifter on the Model B's.
Stan
Scott
10-07-2000 15:51:53
I've got a 51 "B" and a 45 "A". No "top" on shifter. Never seen one on a lettered tractor.
Stan
10-07-2000 12:57:59
My '41 B does not have a screw-on top on it. Our '49 A did not have. Our '52 B did not have. An old brochure from 1947 does not show such an item on either the A or B.
In a nutshell, I surely don't think it's original.
Maybe it's from a Model 50, but I don't know if they would be interchangeable.
Stan
