JD 60 Lift Pressure
BEN
10-06-2000 18:21:51
I want to move round bales with my 60, but it only will pick them up alittle, and the round bale still drags the ground, can the lifting pressure be increase? Bales weight about 1000# each
DP
10-06-2000 22:37:17
 Re: JD 60 Lift Pressure in reply to BEN, 10-06-2000 18:21:51
Hi BEN, Sounds like either someone has removed some of the relief washers, or the spring has weakened. The last I needed them, they were still available fron Deere. You should barrow a pressure guage from your dealer to be sure where the pressure realy is.
