JD B
3 point hitch
Bill Oakes
10-05-2000 10:47:42
Well, I finally have my first John Deere, a 1952 model, at home. I will be restoring it over the winter. My guestion: Is there any sort of 3 pt hitch conversion kit available for this great old tractor? It does have what I believe is called a "rocker shaft" hydraulic lift at the rear of the tractor. I would love to cut grass with it. I have a new 6' finish mower, currently being used on one of those other tractors. Thanks for any help you can offer.
Tim M
10-05-2000 17:56:53
 Re: JD B - 3 point hitch in reply to Bill Oakes, 10-05-2000 10:47:42
I would go with a Hoxey Hitch. The page says it costs $140 if you build it yourself. the plans cost $40.hope this helps Tim
Ray Peterson
10-05-2000 17:00:36
You might also want to look at the Worksaver site at worksaver.com - they also have a selection of 3-pt hitches for older tractors.
clooney
10-05-2000 15:36:53
Bill, there are a few options for you. You can install a J.D. 800 or 801 hitch but they are quite pricy & don't work as good as an aftermarket hitch. I am partial to the hitches from... Saginaw County Tractor Parts...http://www.saginawcountytractor.com/ but there are many excellent aftermarket 3 point hitches out there & you should probably get one from a place that is near you as they are quite heavy & the shipping would be expensive from a distant vendor.
