2510 starting hot problem
mike
10-05-2000 06:49:04
was a gas engine replaced it two years ago with a fresh rebuilt diesel. started to get hard to start this year. rebuilt the starter and a new batt. it still wont start hot. the starter just can't turn it over fast enough. It is a diesel starter,the old gas starter couldn't do it. hope some one can help thanks, mike
ROBERT
10-06-2000 16:30:24
 Re: 2510 starting hot problem in reply to mike, 10-05-2000 06:49:04
WHINE YOU INSTALLED THE NEW ENG DID YOU INSTSALL
2 BATTERY THOSE LONG AND THIN BATTERS DONT HAVE MUCH JUCE
ONLY 450 CCA I THANK,MAY NEED TOO INSTALL BIGER
BATTERS ROBERT
G Taylor measure voltage
10-06-2000 03:40:54
Use an analog voltmeter across the starter. Positive post on starter ( no where else) and to the starter body/casting while cranking. Then measure post to post not connector to connector at the battery. Should have 12.5V at the battery while cranking and 12.1V to 12.3V across the starter windings.
Ray
10-05-2000 07:39:54
Had a diesel and a gas did the same thing,rebuilt
starters and installed new batterys,didn't help.
Turned out to be bad battery cables.Both had
the cables replaced at sometime,but with smaller
cables.These take larger cables.
