630LP 3Pt Lift
John in OK
10-04-2000 01:55:09
Our 630LP with factory 3 point will not lift 1200lb round bales. Is this normal? If not normal what should we look into to fix it? Thanks for the help
John in OK
G Taylor
10-10-2000 20:42:34
 Re: 630LP 3Pt Lift in reply to John in OK, 10-04-2000 01:55:09
What is the system presure ? Is the relief valve opening early or the system unable to achieve 1100psi?
STMTS
10-04-2000 19:24:46
What type of hyd. oil do you have in it?You might try draining it and using 30wt non-detergent motor oil,new hyd. oil is too thin for a worn pump.Or the seals on the rockshaft piston maybe leaking
