JD400 Overheating/Timing
Anthony Warren
11-11-2003 19:09:47
Hello,
I made an earlier post on the messageboard regarding timing, but I still have this same problem. I have looked all over for the timing mark and I can't seem to find it.
The reason I checked the timing in the first place is that the JD400 will cut grass for about 10 minutes, then start to have a different smell (similar to flooding), overheat and cut off. I would have to let it sit for about 20 minutes before it would start again (trying to start it before 20 minutes had passed gave us a backfire). After about 20 minutes, it would start up, run fine for about 10 minutes, and then cut off again.
First, I thought it could be the timing causing it to overheat. I marked the timing mark on the flywheel, as per the service manual, but could never find the timing mark. So I thought a key on the cam gear had sheared off, throwing the timing off. So I removed the motor, tore it down, and checked both gears, and they were fine. I reinstalled them, per service manual, and timed the governor, motor fired right up with no problem. I cannot find the timing mark, however. I have enlarged the hole, but alas, no timing mark. When you engage the mower deck, it does the same thing as before, mows for 10 minutes, and then quits.
I talked to a mechanic from a JD dealership, and he stated that if the gears were in line, and the governor was in line, then that's all you could do, and don't worry about the timing mark. I don't feel comfortable with this, however.
I've replaced the points, condenser, coil, plug wires, plugs, and the air filter.
What else can I do?
Thanks in advance.
mike
11-12-2003 06:11:24
 Re: JD400 Overheating/Timing in reply to Anthony Warren, 11-11-2003 19:09:47
The only time i worked on engine like this I had trouble lining up the govener timing marks. It would run with it one tooth off but not right and cound not get timing set do to no mark visable with timing light, had to remove govener and move one tooth to make it right. get abook you'll fgure it out
