48 A flywheel endplay and adjustment
Wayne
10-01-2000 15:17:57
Two questions:
How much end play should you have and how to you gauge this?
I can't keep the flywheel bolts tight. How do you keep them tight?
Shorty Dear
10-03-2000 18:59:42
 Re: 48 A flywheel endplay and adjustment in reply to Wayne, 10-01-2000 15:17:57
A John Deere flywheel wrench will tighten those bolts tight enough they won't come loose.
Dave Kolby
10-02-2000 17:06:39
Well, I set mine just by feel. Been doin it a few years so seems to work okay. I push the flywheel on the shaft till there is no play and then tap it out enough so I can barely feel some play and tighten it down. As to why your nuts come looose??? Don't know, mine stay tight. Is the flywheel moving on the crank, that is increasing the end play? I do have to tighten them down pretty hard with a wrench and a pipe. Probably some better ways than mine to do it.
dave
Scott ks
10-01-2000 21:09:20
Hi Wayne,
If you can get between the flywheel and the block use a feeler gauge. Pry out on the flywheel and measure record measurement remove pry instrument and push in on flywheel measure again subtract and you will have measurment.
Scott
Scott ks
10-01-2000 21:08:15
Hi Wayne,
If you can get between the flywheel and the block use a feeler gauge. Pry out on the flywheel and measure record measurement remove pry instrument and push in on flywheel and you will have measurment.
Scott
Scott ks
10-01-2000 20:58:17
Hi Wayne,
Scott
rolloIngram
10-02-2000 04:12:27
 Re: Re: 48 A flywheel endplay and adjustment in reply to Scott ks, 10-01-2000 20:58:17
I don't know how you can get between the block (case) and the flywheel. I think you have to measure endplay somewhere.
rollo Ingram
10-01-2000 17:04:41
The crankshaft end play range is from .005 to .010 for a 48 A. I used a dial indicator to measure the movement. There is probably a cheaper way, but I happened to have one.
