2240 shifting problems
William Brown
09-30-2000 05:35:57
I have problems shifing out of reverse when under a load, and shifting into park position. I have to work the other shift levers around and some times bump the clutch to move the park and reverse levers. Is this a common problem with this transmission, and can anything be done to make it work easier?
Brian
10-01-2000 15:07:23
 Re: 2240 shifting problems in reply to William Brown, 09-30-2000 05:35:57
We have had similar problems with our 2240. When the trans was flushed and filled the problem got a lot less noticeable. (Someone had put 90w oil instead of the correct fluid in the trans). You might also want to check the level of fluid in the trans before flushing. It may just be low. Good luck! Brian
