Clutch questions
Will In MD
09-28-2000 08:26:20
I have a John Deere Model "BR" and have some questions about the cluth.When i pull the clutch lever back , it does disengage the transmission and the drum keeps spinning.I have to pull back real hard to get the drum to stop and it takes a while before i can put it in gear.Is this normal? and the pad is worn, i am going to try and get a new one hoping that may help. I have also read how to adjust it, but not sure if that has any impact on that. Thanks for any info you can give me. Will
Hand Clutch
10-07-2000 18:12:58
 Re: Clutch questions in reply to Will In MD, 09-28-2000 08:26:20
I agree but if you replace the pulley brake pad and the problem persists clutch adjustment may be the problem...If the clutch adjustment is too far out then by pulling back real hard on the clutch lever you are trying to pull it over center the other way
Dave Kolby
10-02-2000 17:16:13
Twopop is right, the pully is geared to the transmission so if it is in gear and the wheels are turning at all it will turn no matter if the engine is running, clutch is disengaged. The pad on the pully then acts like a brake for the whole tractor, thus wearing quickly. The pad is supposed to be used to stop the pully when running a belt.
Dave
twopop
09-28-2000 20:41:47
when you disengage the clutch with the tractor in gear the pulley will continue to turn until the tractor stops moving.if you are pulling rearward on the clutch lever you are using it as a tractor brake,which will wear out the pad quickly.
BigJ
09-28-2000 10:28:20
I believe if you get a new clutch pad and turn the adjusting screw a little bit and you should have satisfactory results.
