JD 440I Loader Backhoe
Steve Golden
09-27-2000 17:18:33
I recently purchased a 440I. I dropped off the backhoe and I see that there is no PTO(although there is a lever by the gear shift) and no 3 point hitch or hyd. for it. Is it possible to install a 3 point and PTO? That way when I dont use the backhoe I can run implements. Also i am told that pulling stumps can make a tractor flip but what if you pull in reverse?
Thanks STEVE
Jonathan
09-27-2000 21:13:34
 Re: JD 440I Loader Backhoe in reply to Steve Golden, 09-27-2000 17:18:33
just a comment on the latter portion of your posting...Most transmissions are not designed to do a lot of "work" in reverse...hence it tends to be of a weaker design than the forward gears....and if you have a backhoe, why not dig the stumps ??
