JD 2030 stuck in Lo gear
George Brun
09-27-2000 13:01:34
I have a 1975 John Deere 2030 with a collar shift transmission. The Hi/Lo range shift lever is stuck in Lo gear. I was wondering if anyone else has experienced this problem. Could it be that the shift lever has slipped out of the brackets on the shift shafts or am I possibly looking at splitting the tractor and having to pull the shift shafts. The shift lever also seems to be in the neutral position instead of at the top/right of the H pattern.
dirty john
05-08-2004 18:15:58
 Re: JD 2030 stuck in Lo gear in reply to George Brun, 09-27-2000 13:01:34
If you lift the gear shift lever out. After you take the clip off under the rubber boots. Get a light and a screw driver you will be able to move the blocks back were they belong . Set the shifter back in and see how you did before putting the clip back
david val
09-27-2000 20:54:34
you are right, the shift lever slipped bwtween the shifter shaft attachments. could be the attachments are loose at the rivetting to the ahafts. anyway, you can put it in neutral by removing the shift lever and moving the shifter shafts back to neutral.
david
