60 head
richard
09-27-2000 09:03:30
need to know how to put model 60 head on a model A johndeere
Mike Aylward
09-27-2000 16:25:23
 Re: 60 head in reply to richard, 09-27-2000 09:03:30
Richard, it is really pretty simple, but you will need some parts. The head is a direct bolt on, but you will need a 60 head gasket. The push rods are the same. You will need a manifold, carburetor, and air intake up to the air cleaner. Your rockers will probably work, but I prefer the 60 rockers as they are heavy steel as opposed to cast iron on the A's. You will also need a 60 valve cover because it has a small indentation in it to clear the carburetor float bowl. You may also need a different ventilator pipe. This will wake up your A a little as the 60 head has about a half point more compression due to the tighter combustion chamber, plus the duplex carburetor will give you a smoother idle and more throttle response. If you have any other questions feel free to let me know. Hope this helps. Mike
