410C
Kevin
09-27-2000 08:14:52
Can anyone tell me where the neutral safety switch
is located on a mid 80's 410C Backhoe?The machine will only start IN gear.
Jonathan
09-27-2000 21:09:09
 Re: 410C in reply to Kevin, 09-27-2000 08:14:52
...it is located on the left side of the reverser on the shift valve/clutch valve housing...not the easiest spot to access...You can try removing the battery box cover and go in thru that route, or try from the ground, up between the frame and the reverser...If you remove the battery box cover , and shift the reverser forward to reverse and back, you will see the linkage moving to locate the valve assembly..It is screwed into that valve housing in line with the shift spool
