JD 50 Brakes
Help
Bruce
09-26-2000 20:33:06
What is the procedure to remove the brake drums? My tractor is a 1953. Also, is there an easy way to remove the grill?
Mike
09-27-2000 11:37:11
 Re: JD 50 Brakes - Help in reply to Bruce, 09-26-2000 20:33:06
If you can't get drums off easily then remove 3 bolts that hold entire brake assmbly to rear end housing. The whole unit will slide out. Put in a hyd pres and remove drums. Real simple procedure. As long as you have it off, take everything apart and clean/ lube / never sieze it. Should take less thann an hour per side. Good luck, Mike
Charles
09-27-2000 00:40:10
Take the large nut off, perhaps loosen the adjusting screw for shoe clearance, and pull the drum off.
I have the same year and model.
In a word, no. Well, it's not that bad, but you have to take off a few nuts/springs/bolts to remove the nosepiece. Then you can disassemble the grill screens from the inside, I think.
Fudd
09-27-2000 18:49:42
 Re: Re: JD 50 Brakes - Help in reply to Charles, 09-27-2000 00:40:10
Mine is a 53 too!
