Jd 2040 brakes sticking
tomp
09-26-2000 19:29:39
i recently acquired a 2040 with sticking brakes, the machine has low hours and has been setting for quite some time in a seaside environment, the brakes are very firm but do work, yet machine will not roll back in nuetral except on a steep hill. should i continue to run and see if brakes improve or is there a trick for unsticking. Also does anyone know if these are wet brakes?
thanks for any help.
david val
09-26-2000 21:04:27
 Re: jd 2040 brakes sticking in reply to tomp, 09-26-2000 19:29:39
the brakes are wer. check for water at the trans. oil. water can ruin the brake linings and make them swell thus stick them.
another proplem ma be with sticking pedals.this can be treated by use if good penetrating oil on the pedals and shaft.
anyway, all jd's of the type of the 2040 have some drag on the brakes and need some force to overcome this drag and start moning.
david
