JD 730 Flywheels...
Wally Pfennig
09-26-2000 14:30:36
Is there a common problem with JD 730 Flywheels ? If so, what is it. Thanks in advance.
TB SCOTT
10-06-2000 14:15:54
 Re: JD 730 Flywheels... in reply to Wally Pfennig, 09-26-2000 14:30:36
I BOUGHT A 720 DIESEL IN 1985 WITH A TAPER-LOK FLYWEEL ON IT AND HAS NEVER SINCE LOOSENED UP. THIS TRACTOR IS USED ABOUT 200 HOURS A YEAR AND I HAVE CONVERTED IT TO ELECTRIC START. I'M SOLD ON THESE AS I'VE PURCHASED 3 OTHER TRACTORS WITH THIS FLYWHEEL ON IT AND HAVE YET TO HAVE A PROBLEM WITH THEM. GRANTED THIS ISN'T A CHEAP FIX BUT ITS ONE LESS THING TO WORRY ABOUT. FIX IT AND FORGET IT..... .GOOD LUCK.
deerejon2000
09-27-2000 07:37:21
The diesels had problems keeping the flywheel tight. They would wear the hub and crank enough that there was no way of getting it tight. In fact, 70 & 720 diesels all had this problem. There are several atermarket fixes for this, including a company in Ohio that sells remanufactured flywheels and special hubs or the hub and new steel flywheels.
Phil H.
10-02-2000 15:18:26
 Re: Re: JD 730 Flywheels... in reply to deerejon2000, 09-27-2000 07:37:21
I bought a styled G along the side of the road about 3 years ago. It has been sitting in a barn ever since. I have the same problem. But, I can't get the flywheel off to examine what is wrong. Are there special tools or some "simple" way. So far I have found no simple ways to fix anything, but it is fun.
Phil
