530 starter problem
Ray
09-25-2000 19:16:36
When i go to start my 1959,530 sometimes the
starter just clicks.If i push the button several
times it will start right up.It might start good
for a week,and then you have to keep hitting the
starter button over and over again.I've tried
jumping it at the starter,but it doesn't make any difference.Thanks
John T
09-26-2000 07:55:29
 Re: 530 starter problem in reply to Ray, 09-25-2000 19:16:36
Ray, my opinion, in order of likelihood, the problems are: Loose or corroded/carboned up battery or ground connections, loose or carboned up connections at the solenloid or starter, bad/loose/carboned battery cable ends, bad solenoid, bad battery, bad contacts on the starter switch, and only after all that a bad starter (brushes worn etc.). Ol John T
DJHinMO
09-26-2000 05:28:48
Sounds like a bad battery or bad connection between the battery or starter. A dead cell in the battery will make it act that way.
