Hey Clooney and John T
BigJ
09-25-2000 18:09:42
I got my voltage regulator on this evening and polorized it and she charges great.I had found dirt in the generator along with lots of rust and stuck brushes and even a wire that had been worn through the insulation that was touching between the field and the gen.It is not right on 14 volts like an alternator but it is 13.5 volts and the lights are brighter than they ever have been.The engine even feels crisper than it did.I just wanted to say thanks for you two's replies and to others that have helped me along also.Jack(TN).
John T
09-26-2000 08:01:07
 Re: Hey Clooney and John T in reply to BigJ, 09-25-2000 18:09:42
Big J, your certainly welcome even though I forgot your question and my answer by this time. A generator output of 13.5 is pretty decent and I so many times find a good clean out and free up of the brush hold down springs is all it takes to make a generator gen again. John T
clooney
09-25-2000 19:19:33
Big J, glad to hear you are up & running. The voltage should be a little lower on you old system than on the new 14.2v alternator system. The 14.2 charging rate is set up to keep the new Freedom type batterys charged & will eventually fry the old standard lead acid batterys if allowed to charge for hours on end while in the field.
