4020 fuel gauge
mgb
09-22-2000 20:18:08
The fuel gauge on my 1965 diesel 4020 hasn't worked in years. I was fooling around with it today and traced the wire from the tank back to the firewall. Looked OK. My question is. With the key on, shouldn't I get some kind of voltage reading at the tank where the wire is screwed to the sender? Is there a way to know for sure if either the gauge or the sender is bad? Should I get a voltage reading at both the gauge and sender with key on? The system is negative ground 24 volt.
twopop
09-22-2000 21:14:19
 Re: 4020 fuel gauge in reply to mgb, 09-22-2000 20:18:08
with the key on you should have 12 volts at the guage and it you touch the sender wire to ground,the guage should move if it is good.
