JD Model A Powr-trol
Harry
09-21-2000 20:02:36
1949 Model A powr-trol leaks oil internal. From the unit into the rear end. Any hints what to look for before I tear into it?
Thanks
Harry
Buckeye Al
09-22-2000 15:06:55
 Re: JD Model A Powr-trol in reply to Harry, 09-21-2000 20:02:36
Start with the power shaft seal between the hydraulic pump and the transmission. It has a floating seal under the tension of a spring. The packing sticks (or rusts) to the shaft, the spring can't take up the slack & then oil leaks past. Drain both the transmission and the hydraulic system. Remove the pump and shaft from the basic housing as a unit & restore the seal on the workbench. Be careful not to scratch or gouge the parts as you remove the pump. There are no gaskets between these parts and they are on dowell pins.
ToddT
09-22-2000 05:30:40
Harry, I have some information about this on my web site. Go to www.jd40.com and look for the Powr-Trol links.
