Polorizing the generator -12volt
BigJ
09-21-2000 14:08:22
I know it is probably a simple process,but how do I polorize my 12 volt generator correctly on my 70.I do not want to ruin my regulator.Thanks
BigJ
09-22-2000 18:58:55
 Re: polorizing the generator -12volt in reply to BigJ, 09-21-2000 14:08:22
Using my old regulator,I polorized the generator and revved it up so it would charge and pulled the battery cable off and it quit.I will be installing a new regulator tomorrow and see if that fixes it.
clooney
09-22-2000 19:35:15
 Re: Re: polorizing the generator -12volt in reply to BigJ, 09-22-2000 18:58:55
BigJ, before you replace the regulator make sure the regulator has a good ground,if that isn't the problem, then run a jumper wire from the (F) terminal (small) on the generator to a bare metal spot on the generator case or engine block, then with the engine running see if it is charging, if it still isn't charging leave the jumper wire on the (F) terminal to ground then add a jumper wire from the (BAT) terminal on the regulator to the (GEN) terminal on the regulator & see if it charges, if it still doesn't charge you probably have a stuck brush in the generator or a bad generator or a broken wire between the generator & regulator or a broken wire between the regulator & the ammeter. If it charges when any of the above things are done you probably have a bad regulator or the wire between the (F) terminal on the generator & (F) terminal on the regulator is open. If you suspect the generator is bad see Buckeye Al's post below to motor the generator for on tractor test. Caution! at no time hook battery voltage to the (F) post on the regulator, or the (F) post on the generator if it is still hooked up to the regulator or you can fry the regulator..
BigJ
09-23-2000 06:03:21
 Re: Re: Re: polorizing the generator -12volt in reply to clooney, 09-22-2000 19:35:15
Thanks Clooney,I am going to do exactly that later today.I think my generator is good because I took it apart and cleaned everything up and unstuck one of the brushes and it looked real good.I can tell you that I did find the arm wire rubbed into the field wire the other day when I took it off to clean it and I suspect that that fried the regulator.I took the top off the regulator and one of the coils was blue where it had been so hot.Thanks
clooney
09-21-2000 15:21:32
Big J, if the regulator is installed & working just momentarily jump a wire between the BAT & ARM terminal at the regulator, if the regulator is NOT installed or not functioning first run a jumper wire from the F or Fld terminal on the generator to the case or ground, then momentarily touch a wire from the NON grounded post ( + if it is neg ground & - if it is pos ground) of the battery to the A or ARM terminal on the generator.
BigJ
09-21-2000 17:32:43
 Re: Re: polorizing the generator -12volt in reply to clooney, 09-21-2000 15:21:32
I have a problem,I can't see the writing on the generator to see which wire is which,and it is a positive ground with the regulator on it.Thanks.
clooney
09-21-2000 18:05:03
 Re: Re: Re: polorizing the generator -12volt in reply to BigJ, 09-21-2000 17:32:43
BigJ, the bigger post on the generator is the ARM. If you can't read the markings on the generator, & the regulator is on it, just momentarily touch a wire from BAT on regulator to ARM or GEN on the regulator. If you can't read the markings on the regulator be careful that you don't run the jumper from the BAT to the F or FLD as that can burn the regulator up. The BAT terminal will have the wire from the ammeter running to it, the ARM or GEN terminal will have the wire that goes to the A or ARM on the generator running to it. The markings on the regulator are sometimes on the tabs under the wire hold down plates (under the screws) that hold the wires on the regulator. If in doubt remove both wires on the terminals of the generator & use a jumper wire from F or FLD (small terminal) to generator case & momentairly touch a wire from negitive post of battery to the A or ARM (big post)on the generator.
buckeye al
09-22-2000 15:35:29
 Re: Re: Re: Re: polorizing the generator -12volt in reply to clooney, 09-21-2000 18:05:03
One other way to determine which terminal is which. Remove all wires from the generator. Remove the drive belt but leave the generator on the tractor. When you jumper from the battery to the ARM or GEN post (which in your case can't be read) the generator will run as a motor. If you jumper to the field terminal it will not run. If it won't motor with either terminal, then you have a generator problem.
If you connect the battery to the GEN or ARM terminal, WHILE the generator is running as a motor, ground the field terminal. It should slow down. It will speed back up when you remove the ground. If you do this last step and it does change speed, you now know that the generator is electrically sound and now it is also polarized! Hook up the belt and the regulator making sure the regulator is well grounded.
John D
10-31-2000 07:54:38
 Re: Re: Re: Re: Re: polorizing the generator -12volt in reply to buckeye al, 09-22-2000 15:35:29
Buckeye Al - Your comments on Sept 21 fit right into a different problem I have on a small 110 JD so I'll jump into this thread. I have a 12 volt generator/motor that appears to be NOT working. I have replaced the voltage regulator and verified all wiring to be correct with continuity. I did as you suggested..... jumpered from battery to gen post(on generator) and grounded generator field post to frame to make it run as a motor. Yep, it slowed down when grounded, as you indicated it would. (also polorized). My question is does this absolutely verify the generator to be electrically sound? When testing from the gen post to ground with a volt meter, I get nothing...nada. Any comments greatly appreciated! John
