2510 PTO guard retainer replacement?
Colin
09-20-2000 18:27:46
On the rear of the transmission case there is a round sheet metal retainer, just left of the center link attachment point used to hold a PTO cover. Mine is badly rusted and I would like to replace it. It looks like it is held on by 2 rivets of some sort, but I am unsure of how to remove it. Any suggestions would be appreciated.
Thanks,
Colin
Duke
09-20-2000 19:20:25
 Re: 2510 PTO guard retainer replacement? in reply to Colin, 09-20-2000 18:27:46
It is held on by a roll pin. Drive it out with a punch.
twopop
09-23-2000 09:56:39
 Re: Re: 2510 PTO guard retainer replacement? in reply to Duke, 09-20-2000 19:20:25
Duke I dont want to sound like a smartass ,but how do you drive those two rollpins OUT if they are already driven IN .Unless someone takes off the whole rockshaft assembly and goes into the differential cavity and drills a hole for each rollpin from the INSIDE of the cavity through the differential housing up to the rollpins to drive them out from the backside.Frankly I would just drill them out from the OUTSIDE.
Duke
09-23-2000 18:07:35
 Re: Re: Re: 2510 PTO guard retainer replacement? in reply to twopop, 09-23-2000 09:56:39
Two pop my error I haven't taken of a latch before just the sheild. I have stared at alot of latches while doing other repairs. Any way I am having humble pie tonite
Colin
09-23-2000 19:26:30
 Re: Re: Re: Re: 2510 PTO guard retainer replacement? in reply to Duke, 09-23-2000 18:07:35
I'm not sure they are roll pins, looks more like a solid rivet of some sort to me, but either way that sounds like a good plan - drill them out from the outside.
Thanks for the suggestions,
Colin
