Weight of JD Model B
Bill Oakes
09-19-2000 17:06:25
I have finally found the John Deere of my dreams. It is a 1952 Model B, narrow front end. I am trying to arrange to have it hauled but need to know what it weights. Can any of you out there help? It does have calcium in the rear tires. Thank You for your help.
Richard S
09-21-2000 19:09:43
 Re: Weight of JD Model B in reply to Bill Oakes, 09-19-2000 17:06:25
My '50 JD B weighed in a 4470 this past weekend at the local pull. One question would be does it have steel or cast rear wheels? Steel rims are alot light than the cast.
JimA TX
09-20-2000 13:17:01
Bill, they are right on as far as the weight goes. These things are heavy. I bought a 50 B earlier this year and hauled it only about 15 miles. I used my regular car trailer and 1/2 ton Ford. The tractor bent the trailer ramps and really loaded the trailer and pickup down. It did have calcium in the tires and weights on the front so it was really heavy. For long trips you need a heavy duty trailer and hitch.
Chuck
09-20-2000 17:47:42
 Re: Re: Weight of JD Model B in reply to JimA TX, 09-20-2000 13:17:01
the other writer is right on when hauling. I used a tandem with 7500# axles, which is DOT approved and tow gooseneck with 1 ton dually. No light pickups should be hooked to these light trailers....you're headed for disaster...
Chuck
09-19-2000 19:01:10
have had several B's, and at pulls they weighed in about 4400 dry...I believe the calcium would add about 400 lbs per tire so gross would be around 5200-5500#s.
Bill Oakes
09-20-2000 06:12:30
 Re: Re: Weight of JD Model B in reply to Chuck, 09-19-2000 19:01:10
Thanks Chuck, your estimate is a little lower; I like that. I am wondering what causes the variety of opinions on weight.
Alan
09-19-2000 17:21:54
I also have a 52 B that I pull every weekend and with no calcium, it wieghs 4500lb.
With the tires it will wiegh some where around 6500 to 7000
Bill Oakes
09-19-2000 17:37:48
 Re: Re: Weight of JD Model B in reply to Alan, 09-19-2000 17:21:54
Thanks for the response Alan. I am surprised it is that heavy. If you are correct I will have to look for a bigger truck. Thanks again.
