JD B Rear Wheels Seals
Tractor Nut
09-18-2000 18:14:40
Trying to remove wheel seals from my JD B. How do they come out??? Where can I find new ones???
Can anyone help?
Thanks alot
Addicted Tractor Nut
John in OH
09-22-2000 20:39:46
 Re: JD B Rear Wheels Seals in reply to Tractor Nut, 09-18-2000 18:14:40
These inner oil seals are a pain to remove. I found it necessary to remove the axle from the rear end before I could get the seal out. The easiest way to remove the axle is to loosen the nut on the bullgear and turn it out flush with the end of the axle threads. Drive a wedge between the two axle nuts to force the outer axle bearing dust seal cap out of the press fit axle housing. Then remove the bullgear and axle. Insert a long rod from the outer end of the axle housing to the rear face of the oil seal and drive the seal out. The new seals are available from JD.
al
09-19-2000 04:44:46
They are on the inside. You must remove the rear cover, power lift or power trol depending on how your tractor is equipped. Remove the Bull gears and axles. The seals are next to the bull gears. The felt rings on the outer ends are just dust shields.
The seals for my A were available at JD. For my 37 B, I had to get a cross reference to a NAPA part.
Good luck
BT from NE
09-20-2000 19:28:42
 Re: Re: JD B Rear Wheels Seals in reply to al, 09-19-2000 04:44:46
Thanks al
