JD 1948 A Clutch Disk Orientation
Rollo Ingram
09-18-2000 04:35:38
Help! I took the clutch disk off my '48 JD A to get access to the crank bearings and now, I need to be able to put it back on. I didn't think it could be counterweighted, snice it was just a small circle of steel, but it weighs more on one side than the other. My I & T book talks about lining up "V" marks between the crankshaft end and the clutch disk, but mine must be worn off. There are no line-up marks that I see. Does anyone know how the disk should be lined up with the position of the Crankshaft? Any help would be appreciated.
Fudd
09-18-2000 20:26:14
 Re: JD 1948 A Clutch Disk Orientation in reply to Rollo Ingram, 09-18-2000 04:35:38
A picture is worth a thousand words. Hope this helps, it's out of my 50 manual. Good luck
Rollo Ingram
09-19-2000 04:20:07
 Re: Re: JD 1948 A Clutch Disk Orientation in reply to Fudd, 09-18-2000 20:26:14
Thanks for the picture,but unfortunately, the "V" marks on both the disk and shaft are worn (rusted?) off. Somehow, I need to figure out the relationship between the "weighted" side of the disc and the position of the crankshaft. Not an easy problem...I appreciate the effort.
