JD H Rebuild Specs
Donny-B
09-17-2000 18:36:33
I am starting to rebuild a 41 John Deere H. Can someone tell me what the max oversize wear limit is on the block before it must be re-bored? I also would like to purchase an indepth service manual for the same. Thanks in advance.
Paul from Michigan
09-17-2000 19:42:55
 Re: JD H Rebuild Specs in reply to Donny-B, 09-17-2000 18:36:33
My book shows .003-.006' clearance, but you can probably get away with more than that with new rings. The old cast iron pistons can be knurled to take up some of the wear too. I have had cylinders that had .005 taper work OK with new rings. Hope this helps, Paul
