JD LA Idle
Putt-Putt
09-17-2000 17:25:34
My LA starts well - good hot spark but, seems to require a fairly fast idle to keep running.
Where should I look first? Carburetor or timing?
Maybe both huh?
Any peculiarities with the LA engine?
Thanks,
Putt-Putt
Plough-boy
09-18-2000 14:32:31
 Re: JD LA Idle in reply to Putt-Putt, 09-17-2000 17:25:34
Is your govenor working? When you imply that it will not run at an idle, is the govenor opening up the throttle as the engine speed decreases? Make sure there is no slack or play in the govenor to carb rod.
Putt-Putt
09-18-2000 16:59:46
 Re: Re: JD LA Idle in reply to Plough-boy, 09-18-2000 14:32:31
Yes, governor works just fine. I run the tractor up a slight grade and the governor opens up as load increases. The engine will idle - it just seems it needs to be at a higher RPM than necessary.
Putt-Putt
Plough-boy
09-19-2000 07:15:27
 Re: Re: Re: JD LA Idle in reply to Putt-Putt, 09-18-2000 16:59:46
Here is the Adjustment instructions for the TSX carburator as per an old JD service bulletin. Hope it helps.
Set the stop screw so that the throttle valve is open slightly
Set the throttle to slow idle position. Turn idle adjusting needle until engine begins to falter or roll from richness. then turn needle in the oppisite direction until the engine runs smoothly.
TSX modle carbs 107, 330, 339, 355, 385, 398 use the fuel adjusting type of idle needle. All other TSX carbs use the air adjusting type needle.
Idle adjusting Needle - Air (top)
To richen the idle mixture turn the idle adjusting needle to the right or clockwise.
Idle adjusting Needle - Fuel (top)
To richen the idle mixture turn the idle adjusting needle to the left or counter-clockwise.
Power or Load Adjustment (bottom)
With the engine running at governed apeed under load, turn the power adjusting needle to the right (CW) a little at a time until the power drops appreciably. Then turn the needle to the left (CCW) until the engine picks up power and runs smooth.
