Your opinion...
Karl Bader
09-16-2000 17:07:21
I have recently acquired a John Deere B (1950) for my collection. The engine is stuck, and there is a problem with the carb. I would like to put her through a full restoration but I am not sure if I should do it when I rip into her to unstuck the engine and work on the carb or to wait awhile. What are your thoughts?
Thanks,
Karl
Dave 2n
09-17-2000 17:27:42
 Re: Your opinion... in reply to Karl Bader, 09-16-2000 17:07:21
Clooney's advice is "on the money." It's the only way to do it.
clooney
09-16-2000 17:13:40
Karl, when you take it apart clean the removed parts & prime as you re-assemble it. After you get it running you can check for other problems & oil leaks. I you start the restoration without getting it running & tested you will not be happy when you have to take things apart to repair them. The only way you can be sure everything is OK & not leaking is to use it for a while before restoration.
Wind
09-18-2000 10:12:56
 Re: Re: Your opinion... in reply to clooney, 09-16-2000 17:13:40
Clooney, I am in a similar siutuation in that I already have my '35 B apart and am doing the cleaning while block work is being completed. My question is should I go ahead ahead and paint the frame under the block before I put the block back in? Also, have the brakes off and the same would seem a smart move. Is this correct?
