Serial no. info
John D
09-16-2000 03:25:52
I have two serial no's on my John Deere 1020RU one on the trans.4R1C02531T, the other on the eng. 41TR032104T casted into the eng. block on the right side is a circle with a 67 in it. Can anyone tell me what year it was made? Thanks John D.
twopop
09-16-2000 15:25:20
 Re: serial no. info in reply to John D, 09-16-2000 03:25:52
the serial # would not be cast into the block and the other #does not appear to be correct.the serial #should be on a plate on the right side of the trans housing
John D.
09-17-2000 04:01:19
 Re: Re: serial no. info in reply to twopop, 09-16-2000 15:25:20
Thanks twopop, I belive that I have the serial #. correct.But I will recheck. It is located on the right side of the trans. above the oil dip stick.The metal tag # is SNT 4R1C02531T and the tractor is made in ohio.
John D.
09-17-2000 05:13:30
 Re: Re: Re: serial no. info in reply to John D., 09-17-2000 04:01:19
The tractor was made in DuBuque Iowa not ohio. I typed the post before coffee. Thanks again
twopop
09-18-2000 18:33:56
 Re: Re: Re: Re: serial no. info in reply to John D., 09-17-2000 05:13:30
Im not famialiar with the 1020ru is it a industrial tractor,or ag.the 1020 ag tractor ser # s start at 14501 and gothru 160000.if the C is actually a 0 it could be a 1969
twopop
09-18-2000 18:36:08
 Re: Re: Re: Re: Re: serial no. info in reply to twopop, 09-18-2000 18:33:56
that business about the C is wrong
Stan
09-18-2000 16:20:44
Having lived in Iowa for 17 years, I got used to the confusion between Ohio, Iowa and Idaho. I once saw a T shirt that said, "University of Iowa, Idaho City, Ohio" (or one of those combinations).
Stan
John D
09-19-2000 02:43:03
 Re: Re: Re: Re: Re: serial no. info in reply to Stan, 09-18-2000 16:20:44
Thanks twopop and stan, I rubbed in some black paint on the serial no. plate.And low and behold the last number on the plate showed up,its a 0 that makes the serial no. 4R1C025310T I think it was made in 1966 to 1967. This weekend I making up a frame to hold up the front of the tractor so I can replace the front bushings to try to make the maunal steering a litte more tight. Thanks again John D
