420 Cyl Head Alignment
Prune Picker
09-14-2000 07:11:19
Did a valve job on my '56 420W, and notice there are no alignment pins on the block or head. Anyone have an idea to properly align the head back on the gasket and block? Seems like there ought to be an easy way to do this.
clooney
09-14-2000 15:58:49
 Re: 420 Cyl Head Alignment in reply to Prune Picker, 09-14-2000 07:11:19
Prune Picker, the manual says "place new gasket on cylinder block, then slip head into position, then install & torque the 7 bolts". I have never done the head on a 420 but have done some 40's & all I do is lay the gasket on & lay the head on, when I start the bolts ( some head movment is usually needed) the holes in the gsket will center it, then I wiggle the head to let it center on the bolts, then I torque the bolts starting with the center bolt under the rocker shaft, then the center 2 bolts next to the coolant ports, then the end bolts.
L.C.
09-14-2000 14:31:46
You might try using thread stock (all-thread) and cutting it long enough to stick through the head. Thread the all-thread into the block and slip the head down over the all-threads. Back one piece of all-thread out and replace it with a head bolt; repeat until all bolts are in.
The disclaimer...I've never tried this, but I've heard of the idea.
Let us know what you come up with.
Prune Picker
09-20-2000 12:16:20
 Re: Re: 420 Cyl Head Alignment in reply to L.C., 09-14-2000 14:31:46
Thanks to Clooney and LC. Good ideas. Got the cyl head back on this weekend. The holes that the head bolts go through allow a lot of movement so I centered everything as well as possible and torqued the head bolts. Turns out the pushrods, although perfectly straight, are VERY close to the edge of the holes they go through. Rocker arms and shaft are good, studs are straight, clearance set and motor runs fine. I am a little concerned about the apparent offset of the pushrods through the holes, however. Comments?
