JD A shakes!
CE
09-13-2000 19:44:21
That old "A" that I mentioned in a previous posting has a rather bad shake when its running.... There is no knock but it proceeds to shake anyways! The flywheel is not loose. What could cause this? Again, there is no knock and the engine was reringed a couple of years ago...
Thanks,
CE
John T
09-14-2000 07:00:35
 Re: JD A shakes! in reply to CE, 09-13-2000 19:44:21
I agree 100% with the good ol G Man and Jim there. The shake could well be the flywheel and/or clutch disk is misaligned and its more often the clutch disk, beacause many farmers change them as opposed to ever having to remove a flywheel. The clutch disks often have a v shaped punch corresponding to a mark on the crank to align them and it (or the flywheel) may be a spline tooth off. You see, it shakes if both arent right, because both are built purposely out of balance (to reduce harmonic vibrations) with the imbalances 180 opposite from each other. Good Luck Ol John T
Gman
09-13-2000 20:17:39
CE---by any chance has anyone had the clutch drive dic.out lately,if so check and see if they misaligned the marks on the crankshavt to drive disc.if you get these marks off the hood will cut a shine viberating,just an idea. later Gman
Jim from Stonepile
09-13-2000 21:46:55
 Re: Re: JD A shakes! in reply to Gman, 09-13-2000 20:17:39
How about the flywheel? Is it indexed properly? There should be alignment marks on it and the crank. You might also check with a JD dealer and be sure you have the right clutch disc. Just some thoughts, Good luck- JIM
